SAM_sez Posted March 2, 2021 Share Posted March 2, 2021 Hi. I am not able to edit single wall height of a room. Used to be able to do it in Chief X10 but for some reason the Red edit handle and the edge handles are not showing like here ( Changing Wall and Ceiling Heights (chiefarchitect.com) ) but instead seeing a circular grey handle but its editing globally...ie the all walls in the room. Used to be able to do this before but don't know what i have done to trigger this action. Link to comment Share on other sites More sharing options...
joey_martin Posted March 2, 2021 Share Posted March 2, 2021 Hit the TAB key after you click, you are selecting the room and not the wall. Also, there is a setting in the defaults to change that behavior to select the wall before the room. Link to comment Share on other sites More sharing options...
SAM_sez Posted March 3, 2021 Author Share Posted March 3, 2021 14 hours ago, joey_martin said: Hit the TAB key after you click, you are selecting the room and not the wall. Thank you very much. Yes I wasn't hitting the tab key. Appreciated. Link to comment Share on other sites More sharing options...
