The mess that is my shed dormer cheek walls
GeneDavis
I have had trouble getting dormers right since day one with Chief, which was back before X Chief.
How to do the roof hole, how to specify the walls, using the specs that cut walls when joined by abutting roofs, what to do with the lower wall below the roofs, etc.  It is all bad for me, almost every time.
Maybe I should have used the dormer tool.  I built all the roofs manually.
If you go inside the rooms on second floor where the dormers are, you'll see the mess.  Hope someone can help.  Thanks.
BZ pre.plan
