Remove stem wall from below railings and retain post footing?
plannedRITE
Until now I have been using doorways to accomplish showing posts within Chief. However, I would like to be able to use railings instead, as clients frequently would like to have a railing shown in the plan and it can be tricky to manually move a railing into place.
But when I use a railing as opposed to a doorway, the foundation plan is negatively impacted.
Here is the doorway technique that I have been using (which will show what I am looking to accomplish in my plans. The only polyline I add in these instances are for the larger 24x24 footing represented by the square dotted line).
image.thumb.png.3668ecd9aed9ae0ff413f3311b64cb31.pngimage.thumb.png.08f881af7879293a495ebfa2ba1d1f72.png
This is what I currently have showing as I use a railing (I will also attach the sloppy plan):
image.thumb.png.3b944ec283053d77eb51ea5982bfca0a.pngimage.thumb.png.154b4f3a3442d45451a91517c34ede37.png
Hoping I explained myself clearly! Thank you in advance for the help.
Burnham Heber Addition PROPOSED Idea 1.plan
