Assigning Plan Template
AAcy322
No, but there are some things you can do depending on what you are trying to do.  If all you want to do is use different defaults, you can always import them from other plans.  You can also use the edit area tool to copy the model from one plan into a new blank plan started with another template.  If the problem is that you started a plan with the wrong units (imperial vs metric), then the easiest thing to do is start over.
