myrtsbnye Posted December 7, 2020 Share Posted December 7, 2020 I have a client that would like the plans in DWG format. But when I convert to DWG the walls don't convert properly. It seems that the main layer of the wall is the only thing that converts, both the interior and exterior layers do not convert to the DWG. It is a complex wall with few items on both the interior and exterior layers (Rigid insulation, a secondary 2"x4" insulated wall, strapping, siding, etc). All else seems to convert properly. Any help would be appreciated. Link to comment Share on other sites More sharing options...
yusuf-333 Posted December 7, 2020 Share Posted December 7, 2020 Try two things. 1- Marque sellect all the exported drawing in autocad workspace. Change colour to ether black or white. I dont exactly remmeber working colour, but that usually solves the issue 2- Export hatches button may require to be ticked. Hope that hrlps Link to comment Share on other sites More sharing options...
myrtsbnye Posted December 7, 2020 Author Share Posted December 7, 2020 Thanks for the suggestions, turns out I didn't select Split wall assemblies into layers. Works fine now. Link to comment Share on other sites More sharing options...
