ChiefHarrell Posted November 11, 2020 Share Posted November 11, 2020 Using CA Premier X12 for a short time. Sure this is a dumb question - but, how can I turn off the auto dimensions on the working plan view? Want to show draft to clients but don't need all the dimensions to crowd up the plan. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 11, 2020 Share Posted November 11, 2020 You could also Delete them with Edit>Delete Objects>ALL Floors Button >CAD> Auto/Manual Dims to remove them all at once......and put them back if needed with a single click. In Defaults under Dimensions >Auto Exterior Dims and uncheck Auto Refresh in your Template and they wont appear auto-magically in every Plan if you prefer to use the Temporary Dims instead as I do. M. Link to comment Share on other sites More sharing options...
