ChiefUserSR_Grit Posted November 10, 2020 Share Posted November 10, 2020 hello, I am working on a light commercial remodel and trying to PDF my sheet drawings and when I do so my dashed lines are either showing up as solid lines or not showing up at all. I have checked all my layers and it shows properly on the computer. this is the drawing on the screen... and then when I export to PDF they are gone/solid... the dashed lines are just CAD polylines and you can see the layer is turned on. So I'm not sure what the issue can be. thanks for you help! Link to comment Share on other sites More sharing options...
Kbird1 Posted November 10, 2020 Share Posted November 10, 2020 Try a different PDF Printer , and see if you get a different result ,,,ie try CA's built in PDF printing if using another currently. Another thought would be are you using Saved Plan Views in Layout ? make sure it matches the Plan's SPV ( and layerset) if so. M. Link to comment Share on other sites More sharing options...
