Multi Monitor Issue Fix for Computers with Nahimic Audio
Kbird1, in Tips & Techniques
Member Statistics
Similar Content
By ginamk
Hi,
I'm having an issue with X9 - anytime I open an item and try to change the material type, I get a pop-up box that says "searching for files" and it appears to be searching through my file folders, but it's on a continuous loop searching the same folder endlessly so the search message isn't going away and I have to force stop the program. I've tried opening different files to see if it was just happening with a possibly corrupt file, but it's happening with several different files so I don't think thats it. I called the help line and they are not familiar with the problem. They said I should try my luck here.
Anyone have this problem?
By ADBdesigners
Help! When I am changing materials on cabinets, floors etc. Chief will freeze and I get the spinning beach ball of death when selecting materials from my library. This mostly happens on countertops, floors and cabinets when I am changing to a material from the manufacturer catalogs. Anyone know how to fix this or is this happening to anyone else?
