amiin85 Posted October 7, 2020 Share Posted October 7, 2020 hi there when i download an OBJ file there is a MTL file with it i import it to chief but the object is imported without the materials no color no texture just a dark object how could i import objects with the materials with it?? thank you Link to comment Share on other sites More sharing options...
lbuttery Posted October 7, 2020 Share Posted October 7, 2020 Hi: the .MTL file can be opened in Notepad etc as it is a text file https://fileinfo.com/extension/mtl you may have to apply the materials manually using Chief you may need to contact CA's tech support for advice Lew Link to comment Share on other sites More sharing options...
