layout file to working file
greener21
You have to trace it. I like to convert to DWG with another progam to trace so I can snap to it. Bring it into a CAD detail, check the size, set all to a layer, copy, paste hold position in plan, unblock or you can't snap, lock the layer.  Nothing will snap to a PDF. Lot of folks convert the PDF to an image file (png or jpg) and trace that. NOTE- lock the layer that the pdf, png, or dwg is on.
