Importing From SoftPlan
chorn501
I have a client that used softplan to design a floorplan which they sent to me as a DWG. file. The problem is that when I import the file the lines are only visible if I select the line or block and I am unable to change the line style to make them visible. I am not sure if I am importing it wrong or if there is a way to change the line styles.
