Joshlapp95 Posted September 15, 2020 Share Posted September 15, 2020 Can someone explain to me how to do wraparound stair case? the stairs are not on a deck, the customer wants them 96" wide, and then run back to the platform at a 45 degree angle. I cannot seem to find the way to join the stairs together at the 45. Link to comment Share on other sites More sharing options...
Joshlapp95 Posted September 15, 2020 Author Share Posted September 15, 2020 it works on a Deck, but I cannot figure out how to do it on a standard platform. I have a raised floor section in the house, the customer whats a 96" wide stairway with the stairs wrapping back to the platform at a 45 degree angle. this works fine on a deck where you have a corner to drag them to, but not other wise. Link to comment Share on other sites More sharing options...
Dermot Posted September 15, 2020 Share Posted September 15, 2020 A picture of what you want would help. Stairs can wrap for landings and rooms that are not decks as long as they meet a number of other conditions. Make sure the stairs are going up to the platform. Make sure the height at the top of the stairs is the same height as the platform. If you still can't get it to work, then you should probably post a plan or contact tech support. 1 Link to comment Share on other sites More sharing options...
Joshlapp95 Posted September 15, 2020 Author Share Posted September 15, 2020 I need to join those two stairs. Link to comment Share on other sites More sharing options...
Joshlapp95 Posted September 15, 2020 Author Share Posted September 15, 2020 3 minutes ago, Dermot said: A picture of what you want would help. Stairs can wrap for landings and rooms that are not decks as long as they meet a number of other conditions. Make sure the stairs are going up to the platform. Make sure the height at the top of the stairs is the same height as the platform. If you still can't get it to work, then you should probably post a plan or contact tech support. Thank you! I was able to figure it out with that help! Link to comment Share on other sites More sharing options...
