Bleedorang3 Posted September 14, 2020 Share Posted September 14, 2020 I have two roof planes which should both have flat soffits under the Eave Sub Fascia which work just fine when the roof planes aren't joined, but as soon as I join the roof planes the soffits on Roof Plane 'A' revert to angled, even when the 'Flat Under Eave Sub Fascia' check box is selected. Is there a way to fix this issue? Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 14, 2020 Share Posted September 14, 2020 2 minutes ago, Bleedorang3 said: I have two roof planes which should both have flat soffits under the Eave Sub Fascia which work just fine when the roof planes aren't joined, but as soon as I join the roof planes the soffits on Roof Plane 'A' revert to angled, even when the 'Flat Under Eave Sub Fascia' check box is selected. Is there a way to fix this issue? Welcome to the forums. Please fill out your signature so we know what software you are using as well as the type of machine you are using. This helps us to answer your question. This may be a simple fix, something your missing etc. Would you please post your .plan file. Link to comment Share on other sites More sharing options...
Bleedorang3 Posted September 15, 2020 Author Share Posted September 15, 2020 1 minute ago, Renerabbitt said: Welcome to the forums. Please fill out your signature so we know what software you are using as well as the type of machine you are using. This helps us to answer your question. This may be a simple fix, something your missing etc. Would you please post your .plan file. Certainly! Sorry about that. Attached is my .plan file. Fowler_HQ.plan Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 15, 2020 Share Posted September 15, 2020 12 minutes ago, Bleedorang3 said: Certainly! Sorry about that. Attached is my .plan file. Fowler_HQ.plan One of the baselines was off and a few off angles in the roofs. Easy to take the roof that was functioning, duplicate it and then reflect about the hip.Fowler_HQ.plan 1 Link to comment Share on other sites More sharing options...
Bleedorang3 Posted September 15, 2020 Author Share Posted September 15, 2020 Thank you both for the expertise and help! That's fixed the issue Link to comment Share on other sites More sharing options...
