Lighthouse Posted August 21, 2020 Share Posted August 21, 2020 I had this working, but now I can't figure it out. I want to control the layer display in saved cameras. In the "foundation view" saved camera, I don't want to show joists. In the "framing view" saved camera, I want to show joists. I thought the method was to choose the layers you want displayed, and then save the camera with a unique name. However, whenever I change the layer settings for a camera, it changes them for all the saved cameras. For example, when I have the joists turned off in the "foundation view" saved camera, but then turn them on in the "framing view" camera, it also turns them on in the "foundation view", which I don't want. What am I doing wrong? Link to comment Share on other sites More sharing options...
Lighthouse Posted August 21, 2020 Author Share Posted August 21, 2020 (edited) 9 minutes ago, solver said: Maybe you need a new layer set for each? thanks, I can try that, but I didn't create those before and it worked, just weirdly stopped working. Now all my saved cameras and showing the same layers, which would seem to defeat the purpose. so I tried that and it seems to work, but very cumbersome. I think before (this morning) when I saved the camera view it saved the currently displayed layers, which is much faster and more intuitive. Edited August 21, 2020 by Lighthouse new info Link to comment Share on other sites More sharing options...
Dermot Posted August 21, 2020 Share Posted August 21, 2020 If you want different views to display different things, then you probably need to use different layer sets. See if this help article helps: https://www.chiefarchitect.com/support/article/KB-00765/understanding-layer-sets.html Link to comment Share on other sites More sharing options...
