Little gap between porch and concrete stairs
hieuthuanho
There seems to be a bit of an issue with the wall type you used for the porches.  I switched it to a railing wall and then use the point to point tool to move the stairs into position but then had to switch the walls back for the covered porch..   Also set the covered porch room to " Use Soffit Surface for Ceiling "  Cleaned up your roof planes in the corner and built a cricket to shed the water.
1506696359_project1-rev6-gableroof Chopped.plan
10 hours ago, hieuthuanho said:
I have one question.
What is the right way to build the porch? Using "railing tool" or "room divider"?
Can't say for sure what is the best way as it may have more to do with the wall definition than the wall type.  In your situation it seems to have been the 1/2" exterior drywall layer that was causing the 1/2" offset in your stair location.
