Ugh... did something, floors are now concrete
ChiefMikla
Easiest way to go back is use UNDO after you make such an error.  I assume you've tried that to no avail?
Loads of different ways you could've done it... is the floor material just changed to concrete or is the floor changed from a raised floor to a slab floor?
Provide your plan
Inside the house is a monolithic slab with a 1.25" tile flooring.  ALL that shows up in the 3d view is a concrete floor and NOT the tile.  You can see it in the image I provided.  Also, the rear patio should have the same tile as the lower deck.
2 minutes ago, solver said:
Select a room, turn the Floor Surfaces layer on.
I knew it had to be something simple.  I turned off that layer when I was playing around with garage flooring and forgot all about it. THANKS!
Thank you... that clears it up.
