BostonRobb Posted July 7, 2020 Share Posted July 7, 2020 I am in the process of creating a layout of a house and a detached garage. City officials are wanting to view the elvations of the garage and house individually. When I use the elevation tool it renders an elevation of the garage with the house in the background. How do I remove the "house" so I can have only the garage in the elevation? Thanks in advance for any advice on this. Robb Link to comment Share on other sites More sharing options...
Chopsaw Posted July 7, 2020 Share Posted July 7, 2020 Hi Rob, Welcome to ChiefTalk. Elevation cameras have the option to "Back Clip" the view and then you set the distance in the DBX (Dialogue Box) or drag out the edit handle in Plan View. Depending on what version you have you may also be able to "break" the cross section line and put a jog into it to adjust the view that displays. Your Current Elevation: Link to comment Share on other sites More sharing options...
BostonRobb Posted July 7, 2020 Author Share Posted July 7, 2020 That is exactly what I was looking for! Thank you for the insight and prompt reply. Link to comment Share on other sites More sharing options...
