StanGibson Posted June 28, 2020 Share Posted June 28, 2020 I want to extend the basement a house out from the current basement, with the new addition having a large deck as its roof. i also am trying to create a see through wall (glass or plastic) of a swimming pool that can be seen from the basement. What is the best way to do this? Probably a heavy question, but perhaps somebody can get me started. Link to comment Share on other sites More sharing options...
joey_martin Posted June 28, 2020 Share Posted June 28, 2020 Just break the basement wall and draw what you want. Once you connect the walls back, the foundation will re-generate. Draw the deck above with deck rail walls. The details on this will take a lot of 2D work and some engineering and waterproofing. The pool: Create the pool with polysolids and make one of them clear. As far as how to see if from the basement...again, windows and engineering considering the loads you are putting on the side walls. Link to comment Share on other sites More sharing options...
