External Wall joint corner problem, extended external layer
FahmiSyarif
Hi Chiefs, I need help with this wall joint in the corner. This is a pony wall (lower: custom Brick thick, upper: custom siding thick) meet siding thick at that corner. It result with the external layer of the "siding thick" wall over extended.
If they just joint like what is showing in the plan view. I also attached the plan file. Thanks Chiefs!
design baru juni 23 2020.plan
Is this what you want?
The end of siding wall over the terrace is lining up with the upper pony wall which is proud of the stone below - hence the extended fin.
I deleted the upper pony wall and dragged the white fascia across to replace the upper pony wall.
I then used the Edit Wall Layer Intersections tool to clean up the wall layers in the corner to match how they would be built.
