Measurements
ChiefUserHeiko
X11 -  I don't have much time to work with this program and therefore I am quite the novice.  I am unable to get the program to measure the walls as I am placing them.  After I put in 4 walls the sizes pop up, but not while I am working on placing the walls.
Carol Lotzgeselle
Carol Lotzgeselle
Press Alt_Q , the short cut for general wall defaults and enable Show Wall length , depending on the setting above it will show measurements to the framing (standard) ,siding , drywall etc.etc
You can all Use the Perpendicular Temporary Dimension ( from selected wall ) after you "rough out" the Walls for the house to move walls exactly.
