JollyRoger Posted May 31, 2020 Share Posted May 31, 2020 Hello Everyone, I am having issues with a bonus room over a garage for some reason on this plan and cannot figure out what is going on. I have placed a room over the garage with a 10 pitch gable roof, but instead of the walls being knee walls they go through the gable roof and create a separate roof over the room instead of being contained under the gable roof. I have attached the plan. Any help on getting the walls to go to knee walls that will not go through the gable roof would be greatly appreciated. Thank you, Jeff S. Ollis Highlands_Lot6.3.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 31, 2020 Share Posted May 31, 2020 On that particular plan, the easiest solution is to simply check Ignore Top (2nd) Floor in your Build Roof dialog. Link to comment Share on other sites More sharing options...
JollyRoger Posted May 31, 2020 Author Share Posted May 31, 2020 Thank you so much! That was simple. Running C.A. Premier 12 here. Jeff S. Ollis Link to comment Share on other sites More sharing options...
