dschulz Posted May 10, 2020 Share Posted May 10, 2020 Is there a way to add elevation dimenions to the the floor plan? (see example below) Or create a table/schedule for all the eleveations needed (eg top of wall, top of floor, top of slab)? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 10, 2020 Share Posted May 10, 2020 Yes that can be done manually with a marker and leader line or custom macro's can be used. You may be able to get most of what you need in regards to a Schedule with a modified Room Finish Schedule or Note Schedule with macro's. https://chieftalk.chiefarchitect.com/topic/26281-special-use-arrowswhered-they-go/?do=findComment&comment=211265 Link to comment Share on other sites More sharing options...
dschulz Posted May 11, 2020 Author Share Posted May 11, 2020 thanks again. Link to comment Share on other sites More sharing options...
