Elevation Dimensions
dschulz
Is there a way to add elevation dimenions to the the floor plan? (see example below)
Or create a table/schedule for all the eleveations needed (eg top of wall, top of floor, top of slab)?
Yes that can be done manually with a marker and leader line or custom macro's can be used.
You may be able to get most of what you need in regards to a Schedule with a modified Room Finish Schedule or Note Schedule with macro's.
https://chieftalk.chiefarchitect.com/topic/26281-special-use-arrowswhered-they-go/?do=findComment&comment=211265
