Reference display layer set formats won't change or changes wrong layer set?
JoeinNorCal
Hi all.  Thank you in advance. I'm inexperienced in this forum, and "experienced" in CA via brute force.  Which means that I've got a very confused plan, which, however, I HAVE used to get permits, for MY OWN complex residential remodel.  In California, we get permits any way we can!   I've finally committed to learning to use CA correctly so that I can create "accurate" renderings for marketing purposes to help virtually sell this house during pandemic.  Please forgive my apparent lack of manners and 1st order stupids in plan.
I believe that I HAVE changed all the layers in my reference display layer set to red.  That change doesn't show.  If however, I define reference set lines as dashes rather than solid, THAT change does show.  There is other related display stuff happening that I don't understand - other things show up dashed....
I don't yet know how to upload images, so have attached PDFs.  My plan is 158 MB.  I couldn't upload it.
Discouraging way to start my day!
Screen Shot 2020-05-08 at 9.42.53 AM.pdf
Screen Shot 2020-05-08 at 9.43.13 AM.pdf
Works just like a PDF -- when you do a screen capture, save as an image (png, jpg), not as a PDF.
Make a copy of the plan. Use Edit Area (All Floors) to marquee around most of it leaving at least one room defined, and delete.
Upload the smaller plan if it's still showing the problem.
    30076
    McCallOfTheWild
    McCallOfTheWild
