walkthru render que?
tcbcanondraft
Hey there i'm fairly new to all of this, im currently doing walkthru renders for condo's at work and i was wondering if there was a way to que up a few of them and let them run like you can with the Ray Tracing etc.
I did a search and couldnt find anything. Any other tips for a newb would be appreciated, Thanks!
If you like you can do a long walkthrough path and let it render overnight and then edit the segments of it you want to use with third party software but as far as I know only one at a time.  I suppose you could run two if you had two instances of the program open but it would likely take twice a long to run if it worked at all but maybe that is what you are after, could be worth a try.
Lots of other details to search if you just lookup "Walkthrough"
Welcome to the forum. :)
8 minutes ago, tcbcanondraft said:
Thanks for the helpful comment! I just might try the one long walkthru and chop it up in Adobe Premier.
I guess one little tip would be to run a quick low quality preview before you set it to run overnight at 4K and then find out it is not what you were expecting.
