MichaelJerome Posted April 25, 2020 Share Posted April 25, 2020 I have updated my defaults to allow for a 14" floor truss between the two floors. All the dimensions show in the default setting DBX accurately but when they are commanded to reset to defaults the first floor adds 2" to the ceiling height but does not create the 14" space for the floor trusses. Let me know if someone sees something I missed. Thanks, Megale Center Plan 2.7.20.zip Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 25, 2020 Author Share Posted April 25, 2020 Sorry Megale Center Plan 2.7.20.zip Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 25, 2020 Author Share Posted April 25, 2020 Thank you - Is there any reason why the reset to defaults does not update all floors instead of doing this manually room by room? I thought that was supposed to remedy these issues. Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 25, 2020 Author Share Posted April 25, 2020 Okay - Do you know of a simple way to rebuild the floor trusses without changing the size individually? Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 25, 2020 Author Share Posted April 25, 2020 Sorry - I missed that option - I thought it was only for the ceiling trusses. Thanks for your help! Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 26, 2020 Author Share Posted April 26, 2020 Is there a reason the window does not show up after I rebuild the framing as you mentioned? I can see it in the camera view but it does not appear or frame in the windows in framing wall detail. Any thoughts? Link to comment Share on other sites More sharing options...
Kiwideziner Posted April 26, 2020 Share Posted April 26, 2020 is the windows layer turned on in that view??? Link to comment Share on other sites More sharing options...
