CaseyT Posted April 4, 2020 Share Posted April 4, 2020 If you move either of the north or south walls of the hip roof section of the house to be coplaner with the north or south walls of the shed roof part of the house the auto build shed roof deforms. What am I doing wrong? Close to as-Built Roof deforms when wall is aligned. x12-6012 Hampton-asBuilt-tryRoof3.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted April 4, 2020 Share Posted April 4, 2020 1 hour ago, CaseyT said: If you move either of the north or south walls of the hip roof section of the house to be coplaner with the north or south walls of the shed roof part of the house the auto build shed roof deforms. What am I doing wrong? This is an old time issue usually seen when trying to put a Shed Roofed Room on a Gable End but Eric's Tip works in this case too. https://hometalk.chiefarchitect.com/topic/1197-help-with-roof/?do=findComment&comment=6859 It is actually a Setting in the Room DBX not in the Roof Planes themselves as one might expect, all Roof Planes are in Group 0 by default BTW. Link to comment Share on other sites More sharing options...
CaseyT Posted April 4, 2020 Author Share Posted April 4, 2020 Wow! You guys are amazing, and FAST too! Thanks so much for the help! Link to comment Share on other sites More sharing options...
