Hammer7 Posted March 30, 2020 Share Posted March 30, 2020 Hello all I'm working on a complex roof line and making steady progress. While I was adusting the railings of this deck I created I moved something, and did not notice that the deck disappeared. I've already drafted some other things that I don't want to loose and cannot figure out what is causing the deck to disappear... any thoughts? A secondary question is how to dictate wall heights by dimension? I'm trying to create a complex roof line and controlling height of certain walls will be helpful. HER.SAMP_3_30.2020.plan Link to comment Share on other sites More sharing options...
Chief16Designer Posted March 30, 2020 Share Posted March 30, 2020 Check if it is a closed room all rails , walls connected 1 Link to comment Share on other sites More sharing options...
Hammer7 Posted March 30, 2020 Author Share Posted March 30, 2020 Thank you, that was part of it, the room was closed but the structure was turned invisible at some point. Still working on it and other things for this plan. Link to comment Share on other sites More sharing options...
