mark2457 Posted March 27, 2020 Share Posted March 27, 2020 Hi All Just starting with Pro 2020 Drawn most of house with gable roof with gables at front and back. need to add 4 -season porch with "half gable" roof, not sure what correct name is, but it's perpendicular to other roof (see attached image). Can't figure out how to do it. I need to set the height of the porch walls (can;t figure that out either) and then need to root to intersect with the wall. Can anyone point me in the right direction? My plan is attached.Plan1.plan Thanks Mark Link to comment Share on other sites More sharing options...
JJohnson Posted March 27, 2020 Share Posted March 27, 2020 36 minutes ago, mark2457 said: Hi All Just starting with Pro 2020 Drawn most of house with gable roof with gables at front and back. need to add 4 -season porch with "half gable" roof, not sure what correct name is, but it's perpendicular to other roof (see attached image). Can't figure out how to do it. I need to set the height of the porch walls (can;t figure that out either) and then need to root to intersect with the wall. Can anyone point me in the right direction? My plan is attached.Plan1.plan Thanks Mark Change the side walls of the porch to High Shed/Gable Walls Set the ceiling height by opening the room dialogue box At least that the way in Chief not sure about HDPro Link to comment Share on other sites More sharing options...
