M-Ferioli
Help with a second floor (X12)
So, I am an interiors user and understand that I may not have the functionally needed for this, but I am trying to help someone out and learn at the same time.
My issues are:
-I added a second floor to this plan but they don't seem to interact well with the flat parapet roof I have drawn and I don't know how to fix it, big gap shown between.
-I also don't know how to accurately move one floor relative to another, I turn on the reference floor but cannot select that layer to measure from, is that possible?
I'm not an architect or builder, I normally draft interior cabinetry so my knowledge of how something like this would be built in real life is limited, so please pardon me if I'm going about this all wrong.
I have attached the X12 interiors plan for anyone that might have a minute to take a look and give me some advice.
Thanks a lot and I hope you are all doing well.
Mike
862511689_floorgap.thumb.JPG.dda0c05cb75810ea617b2ff85c3cd513.JPG1372960116_floorgap2.thumb.JPG.bf50a43a2771f3f7633f86426175de30.JPG
7 Butler Ave REV-0 (07FEB20).plan
You don't want the roof plane running under the 2nd floor. You could delete them and add a layer (or more) to the ceiling structure below.
Draw railing walls on the 2nd floor to form the parapet.
Point to point dimensions will snap to the reference layer. Walls will snap to the reference layer, and there is the Align With Wall Below tool.
Thanks for the help!
Makes sense about the roof.  I guess I didn't try the point to point tool, I'll give that one a shot.
Mike... You can also add a parapet to a flat roof by using a gutter.
Ideally the roof wants to come out to the edge of the outer wall. This walls on that particular floor in check so to speak.
Make a square stock gutter. Say 2" x 6"
In the gutter options Set the y axis plus 2" and the x axis to minus 6".
The gutter sits flush with the EPDM, and is inset, just as you would have in a real world condition.
Then the material gets colorized black to match the roof.
good idea Val.  Only problem is I'm using interiors and I don't have access to gutters that I can see.
That building looks very similar to what I am trying to achieve structurally though so I may have more questions for you as I move along.
Thanks for the input.
Eric, I tried the point to point tool but still could not select or snap to the refence layer.  Maybe a setting I'm missing?
Thanks for that video Eric.  Maybe it has something do with interiors?  I can use the align wall feature without issue but unfortunately no snapping to those refence wall lines for me.  My snapping works as normal for everything else though.
    28875
    JenniferSettlers
    JenniferSettlers
