kabirraji03 Posted March 15, 2020 Share Posted March 15, 2020 Hi, I experience this issue where i have a curtain wall passing through from first floor to the second and in the process opens up the ceiling on the first floor. I would be glad to have a solution to this issue. Attached is a picture for further clarification Link to comment Share on other sites More sharing options...
Chopsaw Posted March 15, 2020 Share Posted March 15, 2020 Can you post a test plan ? And what would be your preference to see there ? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 15, 2020 Share Posted March 15, 2020 If drywall would work for you... Try an invisible wall with an open below room that you can squish to be almost nothing. Link to comment Share on other sites More sharing options...
kabirraji03 Posted March 16, 2020 Author Share Posted March 16, 2020 Yes, dry wall works........ Thanks. this is what am looking for Link to comment Share on other sites More sharing options...
kabirraji03 Posted March 16, 2020 Author Share Posted March 16, 2020 Chopsaw, pls kindly assist with the file so i can study it. still having issues making it look like yours Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2020 Share Posted March 16, 2020 Sorry I did not save the file. However I can easily redo it for you or I could also use your file as the example. You really just need to have a drywall layer in your invisible wall. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 17, 2020 Share Posted March 17, 2020 Here is a Metric plan file for you to look at. Hope it helps. Let me know if you have any further issues. Curtain Wall Test for Kabir.plan Link to comment Share on other sites More sharing options...
kabirraji03 Posted March 17, 2020 Author Share Posted March 17, 2020 Many thanks.The plan file helped. Link to comment Share on other sites More sharing options...
