doitright Posted March 11, 2020 Share Posted March 11, 2020 Does anyone have or know how to create a individual bamboo stalks? I want to use it as a room divider like the attached image and I would need various lengths. I am using X8 at this time. Thank you in advance. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 11, 2020 Share Posted March 11, 2020 The 3D Warehouse has a few. Maybe something you could use. https://3dwarehouse.sketchup.com/search/?q=bamboo Link to comment Share on other sites More sharing options...
doitright Posted March 12, 2020 Author Share Posted March 12, 2020 Thanks Chopsaw but not having any luck with this. This is my first time trying to get something out of 3d warehouse. When I download a file I get the message that it a read only file. When I import it to Chief I get the message that it was an incompatible file. Not sure what I am doing wrong. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 12, 2020 Share Posted March 12, 2020 With X8 you will need to find the compatible version of Sketchup that is 3 or 4 years old. Let me give it a try. Was there a particular file you were thinking may work ? Link to comment Share on other sites More sharing options...
doitright Posted March 12, 2020 Author Share Posted March 12, 2020 I have attached one of the files I tried Thank You multiple bamboo in base.skp Link to comment Share on other sites More sharing options...
Chopsaw Posted March 12, 2020 Share Posted March 12, 2020 Ok let me give that one a try. In the mean time I optimized one I use for X8 x-bamboo.calibz Link to comment Share on other sites More sharing options...
Chopsaw Posted March 12, 2020 Share Posted March 12, 2020 Sorry your posted Sketchup file is too new for X8. I was able to get a 2015 file to load or Collada File would also work. Can you point me to where you found the file or just be sure to open the larger display of the item and click the Download dropdown for older files that are available. Link to comment Share on other sites More sharing options...
doitright Posted March 12, 2020 Author Share Posted March 12, 2020 This was the one. The problem with the other one you sent was that when reducing the length the color shading did not match up with the ribs. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 12, 2020 Share Posted March 12, 2020 Try the 2015 version of this one. https://3dwarehouse.sketchup.com/model/56f2d498-554e-4d86-a3b4-84fbbeaa46c4/Bamboo Let me know if you have any difficulties. On the one I posted, if you need to shrink it you will also need to shrink the material accordingly. It had one of the better material files of the ones I looked at. Link to comment Share on other sites More sharing options...
doitright Posted March 12, 2020 Author Share Posted March 12, 2020 I could import this one but thought i could break up the individual stocks but not so. I did like your previous one but how do I change the material length different from object length? In future should I download sketchup 2015 version for my x8? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 12, 2020 Share Posted March 12, 2020 The material was set at 9 7/8" for X and Y... That was the distance between the rings then you may also need to adjust the Y position for the correct offset. I had that at 3 1/8". It will look a bit odd if you compress it too much. Possibly you could sink them into the ground or basement or just apply the original material on a chief cylinder. Yes for X8 I think it is 2016 or older at least until you upgrade chief. Link to comment Share on other sites More sharing options...
doitright Posted March 12, 2020 Author Share Posted March 12, 2020 Sinking into the ground is an excellent idea. Didn't think of that. You are the master. Thank you for the info. Cheers, Link to comment Share on other sites More sharing options...
