Foundations
James1959
Why does the foundation always screw up my porches? The first picture is the house after I built the foundation and the 2nd picture is before the foundation was built. I built the porch by using invisible exterior walls. It did the back porch exactly the same way.
I will try and fix everything you suggested. I didn't do that on purpose so I guess it's the default.
Should I not use exterior walls for the porch and make them invisible? If not, how is the best way to make porches?
Thank you "SOLVER".
I went in and took off the check mark on all the exterior walls as foundation walls and it worked perfectly when I built the foundation. It didn't drop the ceilings on the porches.
Thank you very much for your help.
I honestly don't know how that was checked but it was and now I know to watch that part. You definitely helped me out. THANKS AGAIN!.
