Designer100 Posted February 22, 2020 Share Posted February 22, 2020 Is there a way to add pre Mfg. brick to outside of the foundation above grade that does not affect the porches etc or parts you do not want it? Newell Cheatheam www.newellsdesigns.com newell.cheatheam@gmail.com x11 Link to comment Share on other sites More sharing options...
builtright3 Posted February 22, 2020 Share Posted February 22, 2020 31 minutes ago, Designer100 said: Is there a way to add pre Mfg. brick to outside of the foundation above grade that does not affect the porches etc or parts you do not want it? Newell Cheatheam www.newellsdesigns.com newell.cheatheam@gmail.com x11 Have you tried the "Wall Material Region" tool? 2 Link to comment Share on other sites More sharing options...
