X12 Layer Sets
ChiefVeronique
Hi Everyone,
I'm getting very frustrated with the layer sets.
The dropdown menu shows only a few layer sets but none of the one I created or even the preset one like, All off, All on.... they are gone.
I see them in the Layer Display Options, but not on the dropdown, so I can’t use them. Any idea? I’m on Mac
Thank you,
Veronique.
There are a number of different ways to change your active layer set for the current view in X12:
- If you are using the Active Layer Display Options (ALDO), you can show the layer set combo box.  It should be there by default in X12.
- You can use the Edit Active View tool to change your current layer set along with any of the other default settings your view is currently using.
- You can add the Layer Set combo box to your toolbars using the customize toolbars.
