Custom toolbar configuration button icon
AgChief
Does anyone know
1) How to get my custom toolbar button icon to show?  I was trying to edit the icon and pulled it off the toolbar and it disappeared.
2) How do I change the icon of that button?  Is it a simple matter of creating a button icon and name the file the same as the custom toolbar?  I noticed that's what the icons are named for the standard buttons.
22 minutes ago, AgChief said:
Does anyone know
1) In the "Toolbar Customization" dbx. you currently have open in your screen snippet, navigate to "Tools" side-bar section.
2) In the "Available Toolbar Buttons" sub-section, search "toolbar," you should see your icon listed there with the associated name you gave for the set.
3) Click and drag the icon up to your toolbar and release.
4 minutes ago, AgChief said:
Well that was easy enough.  And I had obviously done it before.  But I've slept since then...  :mellow:
Also, naming the png file the same as the custom toolbar button did the trick.
Thanks!
You can make your own toolbar icons as well with that method.
ANNOTATIONS.pngCameras.pngDefault Configuration.pngDIMENSIONING.pngDoors and Windows Configuration.pngSCALES.PNG
    32945
    Japyhala0
    Japyhala0
  • Similar Content
    • By stevenyhof
      I ran into this once before, where I open my CA and there are no toolbars on the top and side.
      I found that my saved configuration was missing so I added it back in and set it default [ Switch To ]
      Nothing happens.
      I even reset my toolbars and still nothing.
      Any idea how to get my toolbars back?
      Thank you,
      Steve
    • By Louie_Carter
      Chief X5 question.  I have completely lost my toolbars.  I was trying to create a new one and somehow must have destroyed them.  I tried renaming the Toolbars file to "Toolbars Old" but nothing happens to get them back.  I also tried a reset defaults and nothing there, either.
      Hide Toolbars is NOT checked.
      Attached screen capture shows the exact error message.  Anyone with an answer that doesn't require a full new installation from my CD disk?
      I will thank everyone in advance for some help.
    • By luckyudesign
      What causes toolbars to randomly disappear? This evening working on X8 I exited out of program and when I opened it back up, they were gone. Can't find them. Installed X9, not there either. Any ideas?
    • By fangelo
      Help,
      I just lost all my toolbars!!  Anyone else experience this?   Any suggestions.
      Thanks
