Framing Display Issues
ChiefUserJoe2020
1) Framing for basement walls above concrete pony walls is not visible in the Orthographic Framing Overview.
2) When I add framing for the ceiling of the basement it shows above the roof of the
Can someone help with these problems?
Using:
Chief Architect Premier X11
Build 21.1.0.40x64
Edited by ChiefUserJoe2020
Additional Information
1 hour ago, ChiefUserJoe2020 said:
1) Framing for basement walls above concrete pony walls is not visible in the Orthographic Framing Overview. 2) When I add framing for the ceiling of the basement it shows above the roof of the room above the basement.  Can someone help with these problems?
If you turn off the "walls, foundation" layer in the "3D framing layer set"...you will see the framing.  Of course you lose the foundation wall.  Maybe someone can chime in with a better solution.
  • 1 month later...
I'm having the same or similar issue with Level 0 pony walls. Framing in plan view looks correct, but won't show in any 3D view (standard, vector, glass, etc.) on just those walls. Yes, turning off foundation walls layer does show framing, but not exactly the best solution. Any other ideas?  Thanks, and stay healthy out there!
