Unable to open Samples Gallery file "Bachelor View"
shanecarman
Hello,
I have the student version of X11, with the most recent update, on my Macbook Pro (macOS Mojave 10.14.6).  When I download and attempt to open the Samples Gallery file "Bachelor View", I get the following error message "You are running an older version of Chief Architect Premier Software that does not support the newer features of the .layout file you are attempting to open. There is a newer version of Chief Architect Premier available. Would you like to upgrade now?"
The file will not open, with the error message appearing when I attempt to open the file.  I deleted and redownloaded the file with the same error appearing.  Other sample files open without issue.  Any advice?  Thank you!
Sorry I believe all of the "Batchelor View" files were released as being X12 compatible. Chief files are not backwards compatible.
Can you work with the "Stone Creek" files ?   What are you goals ?   Maybe we can help somehow.   Trial version of X12 may be available in the coming months.
