Oakriverman Posted January 30, 2020 Share Posted January 30, 2020 Looks like the full camera specification tool has disappeared from X12. The only way I have found is to select the camera in floor plan view and open the dialog box from there... 1 Link to comment Share on other sites More sharing options...
Oakriverman Posted January 30, 2020 Author Share Posted January 30, 2020 That's it! Thank you, sir! I guess the tool is now called "edit active camera", but when you bring it up it still says "full camera specification". A bit confusing Link to comment Share on other sites More sharing options...
Dermot Posted January 30, 2020 Share Posted January 30, 2020 I think you mean that it is now called "Edit Active View" and the reason the name was changed is because the same tool works for most views now. For example, you can use the Edit Active View tool for plan views, camera views, cad details, etc. Depending on which view you are in, it will bring up a different dialog. Link to comment Share on other sites More sharing options...
