MarkMc Posted January 18, 2020 Share Posted January 18, 2020 Someone asked about showing various layout options in a single plan file. I don't understand the need for it in a plan file. I do understand needing to keep it all together so here is a method I've used in various forms to deal with showing options. This is set up as a kitchen but the principals apply elsewhere. (I didn't make this up-several folks on the forum, myself included, do this sort of thing for all kinds of projects). A zip file is attached. This is similar to a set I use for kitchens. This only uses a single plan view for each file: an existing, option 1 with plan and elevations and started option 2 only including the plan. Set it up in a single folder that you can copy and rename (I use directory Opus to batch prepend a project name to all the files in the folder). You can have as many plans as you think you will need. To set up: place a point at absolute 0,0 draw walls starting there (that way if you are importing a dwg you can move it so things jive with the layout before tracing) place cameras you expect to need. These are just set for kitchens. For larger project or exteriors set up elevations and sections elsewhere. (I typically only do the options by floor instead of trying to get it all in a multi floor plan until a few things are settled-a bit risky but not as messy-YMMV) send your existing plan (views) and elevations to layout. Once all views go to the first page, select any views on it, go a new page after the last used page (in this case that is the Option 1 Page) then paste and hold position. Relink the view to the new option plan Repeat for each page, copy views, go to new page, paste and hold position, link to new file. This is so much easier working in Arch D than 11 x 17 since it has more views on a page. Relinking is the same problem for either during set up but gets easier once all is in place. Once you have all your option plans and the layout in a folder close it all out. Starting a new project using this: Add a project name, or whatever convention you use for naming files, to each file in the folder-all plans and layout. Open the layout. Go to menu Tools, Layout, Referenced Plan Files (it's nice if you have a hotkey for that ) Relink each file to it's newly named counterpart. Save Get to work. Hope this helps someone. There is quite a bit you can do with these principles if you think about it a bit. Kitchen Options.zip Edit-this is easier now with X12 where it is possible to duplicate pages within a layout OR Have two layouts open. In that case you set up one layout linked to an existing plan and one option plan. Save as, new name, new plan option file, link the entire layout to the new plan file. Open the first layout, both layouts are open, add a new page to the first layout, go to plan page and select ALL the layout boxes, copy. Go back over to the new page, paste and hold position. Repeat as needed. Edit- Using this in a client meeting: Set this up just prior to meeting. Open layout, open each kitchen plan, drag the tab for each kitchen plan off to create a new instance of Chief. That's easiest if you have multiple monitors but can be done on just one with a little practice. Then, one a time, in each instance open the project browser and open a perspective (I use one plan view that is just for showing 3D cameras that I named). During this phase I use tech illustration for rendering type which keeps the client focused on layout and not finishes and uses fewer resources than PBR Now during the meeting you can switch between versions with alt-tab of the mac equivalent. Just be careful how many other views, elevation etc you open depending on your computer resources. Link to comment Share on other sites More sharing options...
ChiefUserTBD Posted July 20 Share Posted July 20 Are there newer/easier methods in CA version x17 "to show multiple options (kitchens or other)" than described in the post from January 17, 2020. c Link to comment Share on other sites More sharing options...
CliffsCris Posted August 19 Share Posted August 19 On 7/20/2026 at 7:26 PM, ChiefUserTBD said: Are there newer/easier methods in CA version x17 "to show multiple options (kitchens or other)" than described in the post from January 17, 2020. c I can think of multiple ways: Project Management keeps all your plan and layout files nicely contained in a single file location and it's easy to make copies of entire plans to work on without needing to rely on an external folder structure. This is how I do it. Anytime I have an idea or a client wants to see multiple options I just make a copy of my current plan and start working in a new plan and rename with a suffix of the plan change I'm making or something that differentiates it from the original. If you don't want to use Project Management and want to work within a single plan file: Make a copy of your plan and rename the new file to your liking Delete the roof and any other floors you aren't working on (keep the other floors if you have multiple floors to show options on) Select all and copy the floor you wish to edit Build or insert a new blank floor Paste and hold position Now you have an exact copy of the original floorplan just on a new level. Repeat as many times as desired and you can edit each level independently to illustrate your options. You can also make multiple copies of your plan file then export your 3D model as a 3D symbol then import each one into another plan file that contains all your floorplans with options in a single plan file. I don't know how effective this method would be, but you can follow the Modeling a Subdivision or Lot with Multiple Structures tutorial to see how to do that. The final challenge is when you have different options in different rooms in different plans and the client chooses options for rooms that aren't in the same plan. Link to comment Share on other sites More sharing options...
