ShowmeCHIEF Posted January 12, 2020 Share Posted January 12, 2020 Hey guys, I am trying to find the location within the settings/defaults to influence the apron size, & profile. I could certainly create cad moldings as a work around but that would get pretty tedious. Any suggestions? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2020 Share Posted January 12, 2020 47 minutes ago, ShowmeCHIEF said: apron size CA uses the Casing size currently I believe though a suggestion has been made to allow us more control. I use a Sill Molding with apron built in if I need something different. M. Link to comment Share on other sites More sharing options...
ShowmeCHIEF Posted January 12, 2020 Author Share Posted January 12, 2020 Thanks guys, I really like the symbol method Solver, that combined with treatments dialog makes it automatic enough. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2020 Share Posted January 12, 2020 A Symbol can work well if you want Drywall returns on the interior but still isn't 100% accurate Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2020 Share Posted January 12, 2020 22 minutes ago, solver said: Yep , it was that thread where I started using a symbol , it is posted over there a few posts below this one : https://chieftalk.chiefarchitect.com/topic/23244-q-window-how-to-do-a-sheetrock-return/?do=findComment&comment=192925 I have not found a reason yet to use it on the exterior. M. Link to comment Share on other sites More sharing options...
