BenjaminZ Posted January 7, 2020 Share Posted January 7, 2020 I am trying to find out how to fix the walls in this plan. This was probably created in an older version of Chief, but I am using the current X11. The lines are so heavy that I can not differentiate between the drywall and the stud. This particular plan is the only one that I have come across that has this issue and I am trying to see what I can do to remedy it. It doesn't seem to matter if I change the thickness under the wall definition or not. I am thinking whoever worked here before did something to it and I have no idea how to undo it. Any help is greatly appreciated. Thank you, Ben Zent Thick Walls.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 7, 2020 Share Posted January 7, 2020 The lines aren't heavy. You just have the same dark blue fill color assigned to that particular wall layer as you do the lines representing that layer. 1 Link to comment Share on other sites More sharing options...
BenjaminZ Posted January 8, 2020 Author Share Posted January 8, 2020 OMG, thank you so much. I feel ridiculous not even paying attention to the color difference from the other plans I have been working in. I appreciate your help. Link to comment Share on other sites More sharing options...
