DianeP Posted December 3, 2019 Share Posted December 3, 2019 Solved see below: K. I did something stupid and can't figure out how to get the layer display dialog box back to its normal size. Minimizing didn't work as this is the minimized size. Can someone tell me what I need to do to get it back to its smaller size. Well I figured it out before I posted my question, and thought I should post it in case I or someone else runs into this again. Maximize the dialog, and then there is a small area in the right lower corner that will allow you to drag the corner up and in with your mouse to the size you want. 1 Link to comment Share on other sites More sharing options...
