winterdd Posted November 9, 2019 Share Posted November 9, 2019 hey guys, got a new project. can someone tell me what i'm doing wrong with my stem wall height not matching. every time i make a porch/patio either by wall commands or railing commands the heights never match. i kept messing with settings under structure and now it's really jacked up. i'd like the stem walls to match all around the house. the garage throws me for a loop too since it has to be a grade level. thanks! plan file attached and a couple snips. p.s. the rear patio will become a screened porch once i get the heights corrected. i will also make the roof when its all fixed as well. Rosene.plan Link to comment Share on other sites More sharing options...
winterdd Posted November 9, 2019 Author Share Posted November 9, 2019 the client wants icf walls which im not too smart on at the moment but trying to learn how the construction works. Link to comment Share on other sites More sharing options...
BrownTiger Posted November 10, 2019 Share Posted November 10, 2019 Like this: You are working way too hard Rob, Use object Eyedropper select the room in the crawlspace and copy it the porch or even the garage Link to comment Share on other sites More sharing options...
winterdd Posted November 10, 2019 Author Share Posted November 10, 2019 i tried and the floors disappeared, lol. i rebuilt foundation and it went back to what it was. edit: you are right. it worked alot better when i went down to level 0 and used the dropper. way cool and alot easier. thanks Link to comment Share on other sites More sharing options...
BrownTiger Posted November 10, 2019 Share Posted November 10, 2019 These things are state dependent. How does your builder build those porches. I am not an architect, this is my hobby. From the engineering perspective I have seen 5 or 6 different ways porches are done. Some places use diagonal hatches to build the porch, others grade beam, not sure why would someone waste icf blocks on the porch. In Indiana, if the finished floor +12" the builders use 2x8 = 7 1/4 to form a slab that leaves 5" between a slab and the rough floor. In this case psolid porch floor. DNester has a really good video. I don't know why would someone waste icf blocks on a porch. Link to comment Share on other sites More sharing options...
BrownTiger Posted November 10, 2019 Share Posted November 10, 2019 Here. Have not made any structural adjustments Rosene.plan Link to comment Share on other sites More sharing options...
