WAShideler Posted October 14, 2019 Share Posted October 14, 2019 I am trying to figure out where I need to go to INCREASE the size of plot plan numbers and compass headings. HELP! I really need for the County to be able to read the numbers tomorrow morning when I meet with the Plans Examiners! TIA Bill Shideler Link to comment Share on other sites More sharing options...
Chopsaw Posted October 14, 2019 Share Posted October 14, 2019 I think there is a default Plot Plan Text Style that you can use or edit to your liking depending on the scale of the plot plan. Open ALDO ( Active Layer Display Options ) and make sure Layer Properties are turned on. Select a plot line of the plan and it will show you what layer it is on and what Text Style it is using. Look for Plot Plan Text Style or hit the define button to make your own. You will likely need a text height of 30" or more. Link to comment Share on other sites More sharing options...
WAShideler Posted October 14, 2019 Author Share Posted October 14, 2019 Thanks..ALDO Did the trick! Thanks so Much,,,,Really Appreciate The Help! Link to comment Share on other sites More sharing options...
