I am having issue with the built in VR viewer, the motion tracking is extremely jumpy and disorienting, It is totally useless for clients as motion sickness sets in with in seconds, I have had to use external programs and they are becoming an encumbering step to the process
You might be better off looking into Lumion or Twinmotion for these services.  I've seen Chief's VR and its no-where near what those other companies provide...and Twinmotion is free right now (though currently Lumion is higher quality).
    29484
    KMarken
    KMarken
  • Similar Content
    • By alexpwalsh
      Whenever I try to do a virtual walk through, I get these random flashes of interior wall and roof layers coming through. It happens with both interior and exterior walk throughts. It looks horrible, see the attached example. I've tried turning off all sorts of layers in the camera view - nothing seems to help and I can't find anyone else mentioning this on here so I figure it must be a setting on my end. Also have tried playing with frame rates and rendering options to no avail. Any ideas?
      Version: X12 Premier Student
      ext_walkthrough5.wmv
    • By kingsgate
      Hello,
      I have the HTC vive, steam set up and am able to tour my projects, but it renders with weird flashes of black, sometimes a rainbow effect, usually fairly blurry. I have all lights, shadows and reflections turned off. Any suggetions on how to fix this?
    • By woodcraftdesign
      I am using the Oculus Rift S with X11
      When I run a rendering in the VR mode, I have teleport lines sometimes.  Sometimes they disappear.  The hand controls or wands work whether the teleport lines are visible or not.  Has anyone had experience with this issue?
      The wands and VR setup works in other programs no problem.  Also I have no complaints with the VR experience within Chief except for this small issue.  I expect the customers or first time users) will be confused.
    • By excelnow
      I am initiating a walkthrough  and all my Landscaping layers are not showing up. All the Layers are on in the plan view
      that I initiate it from but they are off in the walkthrough. What am I missing & how do I fix this?
    • By pgjacob
      HI All
      In a video walkthrough (link below) the under cabinet lights are flickering.  These are simple point lights.  Any suggestions?
      https://youtu.be/i2o3EN6Trwg
      thanks
      melissa
