JLShaffer Posted September 27, 2019 Share Posted September 27, 2019 Help! For some reason CA won't build the roof framing under many of the roof planes on the attached house plan. I believe all directives are in the walls, roof defaults and roof planes themselves. All the roof planes show up correctly in perspective full overview. I am not sure why I can't get them to generate. I also can't get the room over the garage to allow me to specify it as a room. I appreciate any suggestions and help. John 407 Station Plan 9-27.plan.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted September 27, 2019 Share Posted September 27, 2019 1 hour ago, JLShaffer said: I also can't get the room over the garage to allow me to specify it as a room. Make sure none of the Walls are marked as Attic Walls as generally Attic Wall have "No Room Definition" set by default. Or check for walls with No Room Definition Set assuming it is a True 2nd Story on Level 2 , not the Attic or A level you are talking about as Chief doesn't allow Rooms on the A Level. M. 1 Link to comment Share on other sites More sharing options...
JLShaffer Posted September 28, 2019 Author Share Posted September 28, 2019 Thank you Mick and Eric. Both solutions solved my issues! Cheers! Link to comment Share on other sites More sharing options...
