22trobbins Posted September 24, 2019 Share Posted September 24, 2019 Chief Architect Premier X11 Build: 21.2.0.48x64 When I generate a materials list, I have most of my materials going into the "General GN#" category. I have concrete stem walls, stucco, siding, and many more different materials as a part of the General category. How do I setup the conditions that I am designing to be in specific groups and categories. For example: I want to draw 2x6 exterior wall that will generate quantities that go in multiple categories: - siding quantity - insulation quantity - framing quantity - etc. Thanks Link to comment Share on other sites More sharing options...
GeneDavis Posted September 24, 2019 Share Posted September 24, 2019 Have you fully drawn a building, then built all framing, then generated an all-floors material list? Link to comment Share on other sites More sharing options...
22trobbins Posted September 24, 2019 Author Share Posted September 24, 2019 3 minutes ago, solver said: This what I see for a single wall. Yes how can I edit the wall style and what it what materials will report out. Link to comment Share on other sites More sharing options...
22trobbins Posted September 24, 2019 Author Share Posted September 24, 2019 3 minutes ago, GeneDavis said: Have you fully drawn a building, then built all framing, then generated an all-floors material list? Yes. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 24, 2019 Share Posted September 24, 2019 What are you looking to get the material list to report? Do you know how to manage reporting for the framing? It can be as simple as total lf per type, it can be a buy list in standard lengths with scrap figured, or it can report out all the actual lengths in the build. Link to comment Share on other sites More sharing options...
22trobbins Posted September 26, 2019 Author Share Posted September 26, 2019 On 9/24/2019 at 1:52 PM, solver said: That showed a default out of the box configuration. What happens when you start a new plan and add a wall or two? Yes that is a default configuration of how the material list reports. How do I change this default? Link to comment Share on other sites More sharing options...
GeneDavis Posted September 26, 2019 Share Posted September 26, 2019 What exactly do you want the material list to report? Draw a simple 4 wall house, put in one door, one window, auto-build the roof, draw a foundation under it, slab or stemwalls, your choice, auto-frame the whole thing, then generate the all-floors material list. Examine it carefully and then come back here and tell us with specifics, what won't work for you. AFAIK, the only thing you can control as to how quantities are reported is the framing. If you have and use Excel, you can export it as such, open in Excel, and change it to whatever you need. Link to comment Share on other sites More sharing options...
