modified Paladian window
TKInteriors
Thanks in advance for your help....
I need to recreate the window circled in the attached image. Notice the window is inset several inches thus the horizontal header is broken under the arch.
Hopeful someone has done this before.
Kind regards, Tamela
I have never done this before but I played with it a little bit and came up with this, I got it to look like this by making the exterior casing 6" deep you might want to play with it's depth to make it what you want if this is what you are looking for, I have a picture and a plan that I drew it in for you to look at, hope this helps
window plan.zip
I am using x11 and this new file you sent opened.
Thank you so very much. I am finishing up another job this evening but this window project is first on the boards in the morning -- then I can dig into what you did exactly.
