Ravenquills Posted July 19, 2019 Share Posted July 19, 2019 Sips detail pdf's There are also some spec sheets and construction guides in this set of attachments. I have been using them since it seems virtually everything to do with creating a set of plans using SIPS has to be manually done....Most of these are from one manufacturer but they can be modified depending on you use. I have other systems as well. Message me for more. Hope they are of use to some others. Best a r-control_sip-104.pdf r-control_sip-109.pdf r-control-load-design-chart.pdf joist connection (1).pdf joist connection.pdf SIP_Specification06120.pdf sip-specification-thermocore.pdf listing-report-thermocore.pdf architectural-details.pdf architectural-specifications.pdf installation-manual-complete.pdf ThermapanDesignHandbook.pdf ThermapanInstallationManual-ExteriorWalls.pdf ThermapanInstallationManual-Floors.pdf ThermapanInstallationManual-FoundationSIPs.pdf ThermapanInstallationManual-Nailbase.pdf ThermapanInstallationManual-Roofs.pdf 1 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 19, 2019 Share Posted July 19, 2019 52 minutes ago, Ravenquills said: Hope they are of use to some others. Awesome work, gave you a plus 1, do you have any of these in DWG form or a .plan file with these drawn in CAD? Link to comment Share on other sites More sharing options...
Ravenquills Posted July 19, 2019 Author Share Posted July 19, 2019 5 minutes ago, Renerabbitt said: Awesome work, gave you a plus 1, do you have any of these in DWG form or a .plan file with these drawn in CAD? Not yet i am slowly working on it but being self taught it probably takes me 5 times as long. let me spend a little time looking through my files i may have some DWG files from the manufacturer. I am being a little schizo right now trying to make a final decision on manufacturer...... Link to comment Share on other sites More sharing options...
Ravenquills Posted July 19, 2019 Author Share Posted July 19, 2019 UPDATE This is a link to extreme panels they have DWG files for general, wall, floor,and roof. I had forgotten I have them all downloaded but rather than post all their files if you go to: https://www.extremepanel.com/construction-details/ and scroll down you can get as few or as many as you want. They are in PDF as well. Link to comment Share on other sites More sharing options...
